Monkeythree
Not odd as in weird. Odd as in they don't match one another!
Pulled all the front suspension off the car this morning and immediately clocked that the wishbones are different:
The driver side (on the left of the photo) has part number 944.341.150.02 and has an extra lug and an extra hole. The passenger side has part number 951.341.149.10
The issue I have is that I want to replace the ball joints and I have already bought kits to do so. But the underside/sealing of the ball joints are also different:
The passenger side (on the right of the photo) looks like a was expecting a re-buildable ball joint to look with a retaining ring holding the steel seal in place. But the drivers side seems to have a more substantial steel cap which appears to be pressed in place??
Only other difference is that the front bush on the passenger side practically fell apart in my hands whereas the same bush on the drivers side is solid as a rock.
Can anyone explain what I've got and tell me why they might be different? And crucially, are both ball joints re-buildable??
Thanks in advance.
Thanks in advance.
