Parzival_944
Hi all,
I've got the engine out of my S2 for a general refresh and replacing seals and gaskets, as I need to replace the sump gasket I decided I'd consider refreshing at least the rod bearings. However, I have come across a lot of conflicting info about rod bolts/nuts I need some advice on.
Looking in the Porsche workshop manual it only has a torque value for the nuts and that they should be replaced but doesn't mention anything about the bolts? I've read up and down that you should or shouldn't replace them, and if you do you need the rods machined to match the bolts. I want to do this right but I really don't want to pull the whole engine apart to machine anything as a full rebuild was not really in scope...
Any help would be much appreciated.
