S2 shocks - where to buy?
- Thread starter Big Les
Diver944
In the end I got mine from Bert at www.berlyn-services.co.uk because at least he knows our cars and will send you the right version first time.
Back then it was £130 each for the S2 fronts and £60 each for the rears
944psi
Will be replacing the front strut top mounts too?
Thanks, Phil
Big Les
ECP - £133 each for fronts and £40 each for rears (plus VAT). Sachs I think.
or
Porsche OEM - £136.30 each fronts and £90.47 each for rears (plus VAT). Being OEM I think these are also Sachs.
When you say the front strut top mounts do you mean the bearings? If so I was going to have a look at the condition of them and make a decision - as I will with all other ancillary parts when doing the job.
Indi9xx
A lot of people though opt for a Koni conversion which is top adjustable and would cost about £100 more for the pair in a ready to fit condition on an exchange basis and can be supplied as coil overs that are hight adjustable as well. This solution is also available from Paragon as a kit.
