S2 Sill Trims
marky123
Hi,
When i bought the S2 there were a couple of sill trims in the boot which hadn't been fitted after the sills were renewed and painted.
Is it right that the trims only run from the front of the rear arch to under the front of the door, is there another bit that goes from here to the rear of the front arch?
Also, where can i get some of the plastic nuts that hold these sill trims to the underside of the car.
Thanks chaps,
Mark.
The plastic nuts can be had from the OPC for about 50p each (before PCGB discount!). Must be the cheapest OEM part you can buy!
ORIGINAL: marky123
Yes, there is another small section of about 6 inches that runs under the bottom of the front wing.
"The plastic nuts can be had from the OPC for about 50p each (before PCGB discount!). Must be the cheapest OEM part you can buy! "
Great! do you have the part number by any chance??
