timmyturtle
Todays problem,starter wiring.
I have 4 wires,small red/black,red medium sized that runs back to behind the dash under the scuttle panel(drivers side)
One braided wire from the alternator,and one large wire that comes out of the body in that area
The starter has 4 connections.
One is from motor to solenoid(factory fitted)
Small solenoid screw which i believe the red/black small wire went to
I have another very slightly bigger screw terminal which i dont think had any wire
And the main stud terminal with 13mm nut.
Where do the three larger wires go please? My guess is all 3 go to the main stud,but im not sure
Thanks, Tim
Thanks, Tim
