cdickinson
Whilst making the most of the festive break I've finally ordered 968 castor mounts and during preparation today (soaking everything in WD40) I noticed that some of the bushes look very tired (not surprisingly). For example, the outer ARB (??) rubber bush is sagging so much there is a gap of at least 3mm on the inside - this is when the car is jacked up - see attached.
How much of a problem may this be causing, if any at all?
If I should replace, should I go for polyeurethane, or just standard - bear in mind my car is a cabriolet so it won't ever be track demon!
What other bushes should I replace whilst I'm at it? (I'd rate myself as a moderate DIY mechanic!)
My car has covered 52k.
Cheers,
Chris.
Cheers,
Chris.
