s2 timing belts intervals
- Thread starter dann944
ChasR
I know on the new engine, I will be putting on new rollers and belts.
Neil Haughey
pauljmcnulty
There are two things to look at. The belts are every 4 year/40K maximum. You should, to be safe, do a water pump every second belt change but this is down to the guy doing the work. Mine was deemed fine for another few years as it's not doing huge amounts of miles. Also check oil seals and rollers, as I found out. [:'(]
The timing chain and slipper in the 16V cars are a seperate issue, as they aren't in the service schedule. If they were done in 2006, as stated, they should be fine. Were they replaced, though, or just inspected? I'd also consider having the cams checked, but this is a more major inspection.
Neil's suggestion that you inspect the belt every year does make sense, although I'd say it was going too far for most people. The car's not that different from everything else on the road, after all.
