Hi All,
Having studied the forum archive and seen the well-documented issues with dismantling the combination fog/side/aux headlight unit, I was prepared for trouble. Just as well, cos I think I got the lot!
So far, I've only gone to town on the N/S unit. The four securing screws were all knackered, tried drilling the heads off the inboard, more accessible ones. Heads removed, still no sign of movement, so moved to next stage.
Up on ramps, batwing off. Unplugged wiring and removed 3 x 8mm nuts behinhd bumper, removed entire light unit to bench - no problem. I then set to trying to get the screws out by drilling from the rear, through the brass inserts. That worked eventually - unfortunately I cracked the lens in the process. D'oh!
While considering my options for the damaged unit, I thought I'd whip out the other one and get some Plus-Gas on the fasteners. (For reasons I still haven't fully figured out I had taken the car off the ramps and put it back in the garage before I got that bright idea.) So groping behind the bumper I encountered the cooling loop for the power steering hydraulics. I'll have to get it back on the ramps for a proper look but I'm guessing the bumper will need to come off to release the O/S light unit.
I really just wanted to change a sidelight bulb......
So the dealer list price for the complete unit without Club discount applied is £318 each side. I'm pretty sure that is what is going to be the preferred route for the N/S. I might still save the O/S one... but I WILL be using stainless screws on whatever ends up going back in.
Any helpful suggestions, hints/tips, sources for parts or just sympathy welcome!
