Sad day......... Fuel pump not working
- Thread starter 944 man
944Volks
Thought id finally hear my project roar into life today.
Alas no.
Fitted new fuel pump. Nothing.
Jumped pump and it works.
But there is no power getting to connection near pump.
Check fuse 34. All seems good.
Fuel sender is working.
Haynes suggests inline fuse?
Or relay?
Can't find. Really suck. : (
Car is a 1986 2.5 with 3ltr conversion.
Chrishazle
Chrishazle
944 man
944Volks said:Hi.
Yes was looking at DME relay (what does that stand for?) Is that the fuel pump relay?
How do I jump that?
DME stands for Digital Motor Electronics - in other words the Bosch ECU. The DME relay is in actual fact two separate relays within one case.
Turn on the ignition and the ECU/DME is energised. Start cranking the engine and when a pre-set minimum speed is reached, the ECU sends a control signal to the DME relay energising the fuel pump circuit.
944Volks
Got some time to look at it today.
Just some history. Bought blind off ebay. Drove it 200 miles. Only issue was hot start took alot of cranking.
When I got back i jet washed engine.
After 10 minutes it spluttered back to life and I drove into garage.
Changed fuels lines (weeping ) and fuel pump. And rotor arm. And soldered nasty connectors in wire feeds to coil. New battery,
Now will not start.
12v to coil.
Jumped DME fuel pump runs.
On cranking techo jumps to 2000rpm there bounces sparodicly around 500rpm.
Removed number 4 lead put spark plug in lead and held against body.
Cranked for 30 seconds, I got one weak spark.
What the hell could it be or what have I done wrong?
Thanks in advance. K.
I would rather drive without a spare wheel that without a spare DME relay.
