Right then here we go,
I have in the car a Porsche CDR22 with the upgrade sound pack (eg through an amp not straight to speakers)
This works perfectly!
I have just purchased a Becker Traffic Pro High Speed, this unit looks exactly the same as the Porsche unit but has the addition of a GPS aerial socket at the rear of the unit.
The schematics on both units match up with each other perfectly and the existing Porsche wiring loom fitted into the Becker unit perfectly and in the same parts of the unit as the Porsche unit.
The unit powers up fine, accepts the security code, seek finds and stores radio stations, the CD element works and counts the track time track number etc.
However I have no volume at all, whether in radio or Cd mode.
The unit does show the following message "GPS aerial error"
I have a couple of questions I guess for all you HI FI experts
1. I have not yet fitted a GPS aerial would this cause the "no sound" effect.
2. If the answer to question 1 is yes then when I fit a GPS aerial where does it go, does it just sit behind the unit with all the other wiring, does it have to be mounted on the dash, or under the bonnet or in the boot, I don't really want to be drilling holes through the bulkhead or running complicated wiring.
Hope someone can help.
I've also emailed a friend I know who works at Harman Becker, however he only picks up emails in batch mode evry now and again hence my plea to the forum.
Nik
1
Nik
1
