Pianomana440
Sat nav map stuck but still gives directions after changing battery.
Is there a way to reset say nav?
ORIGINAL: Richard Hamilton
Close. Press 1, 4 & 8 simultaneously for a system reboot.
It can take several minutes for the PCM to rebuild it's GPS almanac after disconnecting the battery. Put the car out in the open for at least 20 minutes with the ignition on.
Check out this thread: http://www.porscheclubgbforum.com/tm.asp?m=770120
