sat nav
- Thread starter Guest
Black80XSA
I haven't seen this reported anywhere yet - i'd have a look on renntech.org - if its reported anywhere it will be on there.
marlin
Araf
Choose the town, and try putting in the postcode like RM20 3 or CT2 8. You then have to choose the street.
PCM3 will not readily fit in the 987.1 and is very expensive. Most people that want a more upto date unit fit aftermarket instead.
For the record, I'm not a fan of the PCM3 sat nav - I've always preferred 2d to 3d, but do like the Bluetooth connectivity that it offers.
Boris the spyder
Thanks for that, in that case I will leave well alone. I suppose I tend to forget its 8 years old almost and tech has come a long way. maybe they should have got someone like Gamin to design in car stuff for them but I am sure the new Boxster will be all that. I take it the I-pod tune change has to be done from the I-pod as well ?
Regards Graham
Gordon Attar
Darren SCF777
Talking from experience and I set my heart on a head unit and found out the hard way the 8 year old stuff just will not cut it,and also be aware of alternator whine from the tweeters yes this does happen.
Also note the control units on these things are highly strung..
If I could do it all again :-
I would ask the audio fit shop to recommend a head unit to work with factory fit amp and speakers and optic connections.
Guarantee no alternator whine from tweeters when on phone call etc.
Guarantee they will use existing invisible aerial.
Consider the steering wheel controls if you have any..
Or TAKE a deep breath and ask Porsche to quote to modernise even if for the larf
...or just use a good 150 sat nav when you need it with Bluetooth connect and take no calls in the car.
Note as soon as you install after market say goodbye to Porsche warranty if you intend to get one.
These cars are absolutely brilliant if not a little bit on the high maintenance side..I usually do not have time for weekend wheels but these cars are super ace...enjoy !!!!!
Boris the spyder
Boris the spyder
But you still have the sound quality of the PCM system - oh joy.
Andrew
Boris the spyder
http://www.pioneer-car.eu/eur/products/sph-da120
Not a small job with Bose fitted but did it all myself and no wires cut. Made custom loom. Happy to share details if you are interested
Boris the spyder
That looks a nice unit, like the fact you don't need to chop wiring up. I do want to return it to stock if I ever change it. Does that unit have a custom surround suited to the Boxster. ? A pic of yours fitted would be appreciated. Regards. Graham
