Scanner for 2016 Cayenne
doug.isaacs
Hi all, can anyone recommend a good scanner for reading and resetting fault codes, servicing etc. on a 92A 2016 Cayenne S Diesel? I'm not very up on it all TBH but mine has thrown a wobbly showing faults with stability, 4WD, steering lock, chassis, parking brake and steering lock. I suspect wheel speed sensor but obviously need to scan it to know for definite and which one.
Hi Doug,
I’m afraid that I can’t recommend a diagnostic tool, but you could have a look at offerings from iCarsoft and Foxwell who have a number of Porsche-specific scanners.
Best to contact the sellers directly to get confirmation that they will enable you to reset the fault codes required. If not then it would be advisable to seek advice from your local friendly Porsche Independent.
Jeff
Just a further thought Doug. Just make sure that your battery is in tip-top condition as a failing battery can flag-up all sorts of problems.
Any reputable battery provider will be able to run a test, usually FOC.
Jeff
