Screen wash filters
- Thread starter rooksy
Mine was caused by the non-return valves failing allowing the water to run back toward the reservoir. Simple to fix, bought all new valves, cost £3.00 each from Type 911 in Beckenham.
Problem solved. Don't try just replacing the one that's gone. I did that then another went a couple of days later. Just do the lot in one go whilst you've got access to the pipework.
The OEM pipe clips were a pain so I replaced them with small Jubilee clips.
Hope this helps.
Steve
