Sealing rear lights. What size BUTYL ROLL
T3rra
I'm putting clear lense on the rear, lights need sealing. I. Tried silicone in the past never again. Sunny day turned to down pour. Not the best time off year, but I'm hope to do it quickly in side the body shop when there repairing window trims.
Anyway question is what size BUTYL ROLL do I need? Round bead or flat.
Thanks 6mm x 8mm iv seen some 8mm x 8mm £10
Delivered is there a chance this extra 2 mm, Would be wrong?
Only that it'd have to go somewhere. You see a lot of lights with the black oozing out around the edges. Or, if it's too hard to squeeze out then it will make the lights sit too far out.
