Seat belt and airbag warning lights dont light
Keith
Hi
Both warning lights dont light up during the initial check and the seat belt warning bell doesn't sound. No other symptoms. Any ideas what might be causing this and how to fix? Thanks.
Very odd. Has it always been like that, or has it just happened?
The best bet is to get a diagnostic check done, which should show up what's wrong.
No, just happened. Dealer here in Portugal told me they didnt undersatnd it either! Didnt show any issues on their diagnostic checks.
Is there a Stratford-on-Avon in Portugal? [:D] [:D]
Perhaps you could get them to do the airbag check, and see if the light comes on.
We have moved to Cascais in Portugal and left Stratford behind. Great roads here with nobody on them. The RHD C4S is no particular problem on these roads although had to change the litronics over to LHD units to pass the importation checks.
I will ask them to run an airbag check and see what happens. It was serviced yesterday and it came back with coolant way below the min level so I dont hold out much hope they will find anything. Their best suggestion was to remove the dash and see if a bulb had gone!
