Seat Memory
DRDT
Good morning. My 991.2 C2 seat memory system has stopped fully working. Pressing the buttons 1 and 2 make no difference to the previously programmed seat position, although the mirrors still move and the car systems set up with each key still remain as programmed. Neither can I set the memory either on the keys or car memory buttons. I have checked the fuses page in the handbook and there does not appear to be a specific fuse for the seat memory. Both driver and passenger 14-way sports seats still operate in all modes using the buttons on the seat sides. Any ideas please? Thank you.
I can’t give you a definitive answer, but if there isn’t anything useful in the Driver’s Manual on seat operation this link could give you some ideas:
Worth a try resetting the seat fore-aft and vertical limits?
Jeff
Had a flat battery or replacement battery recently ? - this kind of thing on other models is sometimes "gone into transit mode and forgot some of my options" - if so - needs a "handover reset" done via diags
Jeff
Thanks Jeff - will give it a go.
No change of battery or flat battery. It just suddenly stopped working yesterday.
Problem sorted - thanks Jeff. Moved seat fully back then forward then to middle. Moved seat fully up then down and back to middle. Same with front cushion extender. Memory function fully working again. Another tick in the Porsche ownership taskbook!
Good to know, and pleased to hear that you’re sorted.👍
It sounds as though the logic’s similar to that for resetting single-shot window operation.🤔
Jeff
