Asiangunner
Hi guys,
Once again the wife hinted that maybe i should sell the Lux and as per everytime she brings it up the car has a habit of hearing her and has broken down.
Cars been running great and after a ten min drive to the dump i turned it off then went to start it up and all of a sudden there was only 100-200rpm on idle.
Car struggles to rev and barely gets above 1000 rpm.
The whole ignition system has recently been renewed over the past year, leads, cap, rotor arm, coil have all been changed.
Whilst at the road side I checked the ignition leads and it seems 2 and 3 are now firing at all.
I then got my bro to quick buy replacement spark plugs and he brought them down. Changed 2 and 3 quickly and it made no difference.
I could really use number 4 to check 2 and 3 as only number 1 was left running and number 1 lead could not reach 2 and 3.
The leads are only about 6 months old and are decent magnecor ones, i can't believe that both of them would fail at the same time with no warning.
I have an old set of 1,2 and 4 leads which im going to take to the car tomorrow, i had to leave it parked up 3 miles away :-(
What else could be causing this issue guys? any advice??
