MJL944
The mechanic (very well versed in 944 engines so I trust his judgement) currently fitting upgraded gear linkages to my S2 told me today that he suspects the "˜Secondary Balance Shaft is out of synch' in my car's engine.
I've read up on what the Balance Shafts do and his diagnosis would seem to tie in with why I briefly experience noisy and harsh vibration through the drive-train when slowing down from high speed "" at the point just before you need to change down into 2nd/3rd from 5th. I had the head gasket changed last autumn and this vibration has been apparent ever since that job during which the belts were removed and replaced. Various exhaust system issues that coincided with the HG change (and that have continued since) had caused me to believe the vibration was the result of an ill-fitting new middle exhaust section.
I don't want the current mechanic to look into the possible balance belts issue (as I'll probably not get my car back until 2015 if the glacial progress with the work I've given them so far is anything to go by!). My preferred option is to get the specialist that changed the HG and fitted the new exhaust system to look into the balance belts issue - but, they're 100 miles away from me.
How safe is it for my engine/mounts/exhaust etc. to drive with iffy balance shafts/belts?
The engine idles fine and isn't clattery. The only time you notice the vibration is in the slowing down scenario described above. But, having spent a fortune on the HG job I really don't want to risk damaging the engine on a long drive especially when I have a couple of good OPC options very close by (Nott'm & Leicester). With an OPC doing the job in mind - Any ideas on the likely labour time required for adjusting the Secondary Balance Shaft?
Many thanks
Many thanks
