jez_anderson
I had a look at a 2.5 boxster today and have a few questions:
1. The windscreen was showing some signs of what looked like delamination in the bottom corners, triangular in shape a couple of cm's big, milky in appearance. Is this delam? Is it a problem? Does the screen need replacing?
2. I wasn't able to drive it (another day maybe) but turned on the ignition. All the warning lights went off ok. When I turned it off the light showing the spoiler was lit. Whats does this mean? I did check that the spoiler went up & down by pressing the button near the fuse panel. Worked fine. The spoiler wa down when the warning light was on.
3. The front "boot" was soaking wet. We took out the carpet but could see no obvious damage. The carpet appeared wettest on the bit that goes under the spare wheel. I know that car has not been driven in the last few days. What might cause this if its been stood?
4. It has FSH by OPC's and had got 85,000 on the clock. It was last serviced in Nov 05 but has only done 3/4000 since then. Is that a problem?
5. The old service reports comment on the tyres not being "N" rated but ok. Is this a problem? Would they need to be changed?
6. There was bubbling around the drivers side door catch. I know this is a problem with some older cars. Is it serious? does it need attention or isit cosmetic?
Thats it for now, though I am sure I think of more. Any advice welcome.
