sell me your 944!
- Thread starter j4mou
Copperman05
Edd
Copperman05
Edd
I've spent more than that this year maintaining my car and if you do manage to find one for £1500 it will "probably" need twice as much spending on putting things right. Perhaps as Ed suggested take a look at the 924 market there maybe some nice but not imacculate 924's to be had for around the £1500 mark.
Dave K.
j4mou
Dlknight, I am happy to accept the best I can get for £1500, I am well aware of the costs involved in owning running and maintaining a 944 to a decent standard, as I owned a "mint" 944s up until last year when I was made redundant.
I am still looking for a nice one, if anyone is looking to part with their's for around that figure I have been to see a couple locally and have enquired about others, luckily I have plenty of choice for around that amount, I would obviously rather buy one from here where I know "most" are enthusiasts.
James [
Copperman05
A badly maintained and neglected 944 will probably cause you more expense and frustration than you may want, therefore not really making it worthwhile. So take your time and be cautious.
Good luck in your search..
Edd
j4mou
Make sure or budget for belts, waterpump, tensioners and rollers if they haven't been done (or no proof of them being done). Also with the 16v you mention cam kit? has it had brand new camshafts fitted? these are sometimes known to be a problem on the 16v as the cam chain and its associated slipper pad isn't regarded as a service item. It stretches over time and becomes slack which can cause damage to the teeth on the camshafts, there is also a tensioner which I think is usually recommended to replace too. Do a quick search on camshafts or cam chain and you should find a good few threads of what to ask/look out for.
EDIT: Sounds like it has had either a belt failure or cam chain failure, hence the rebuild... I'd check what work was actually done and receipted for as it may have only had the minimum work required to get it running again rather than a thorough rebuild...
Hope it truely is the bargain you are after [
Dave
j4mou
Anyway best of luck, oh dont take that '994 man' with you, I've been told he knows nothing about 944's[
Keep us posted, as for that money if you dont have it I would like a look.
