Selling Wind Deflector for S2 Cabriolet
- Thread starter Guest
The wind deflector is an absolute doddle to fit. You unclip the black plastic covers on the seat belt retainers, then unscrew the bolt. A bracket is then put onto the bolt and then tightened up again.
The wind deflector then bolts onto these brackets. The retaining bolts are the type designed to be screwed by hand, so you don't have to worry about spanners to put in and take out. The bottom end of the wind deflector is secured with velcro and I will get the correct velcro to suit (dependant on your interior colour).
I will take some photos when I get home later and e-mail them to you. I was absolutely amazed at the difference that it makes. I bought it especially for Le Mans in June this year, means you can hear the radio, hold a conversation without having to yell, in the latter stages of autumn and even into winter, it means you can keep the top down for longer as it also retains heat. The most important thing is if you, or your passenger have long hair, as it completely eliminates the forward draft that you get with convertibles.
As I said, I will e-mail pics to you when I get home.
Phil
