I've decided to buy a Official Porsche service kit and service the porker myself. I have a couple of questions relating to this would be adventure.
1. A recommendation of what's the best oil to use? (10 litres of the stuff I believe).
2. Any advice other than to make sure that the engine is hot when checking the oil level after putting new oil in, I've read that there is 2 oil release plugs that you need to remove, where are they located?
3. Is it necessary to replace the rocker cover gaskets, washers & nylon nuts (as they come in the kit) and how hard is it to do?
4. Is the fuel filter and sparks plugs easy to fit.
I want to ascertain whether it's better to get it serviced from an independent or whether it's worth giving it a go first?
Thanks for any help.
