georgewlfoster
I have an '01 Boxster 2.7 and need a couple of things sorted on it. Can anyone help?
The indicator stalk switch has failed again (just lasted a couple of weeks - it seems to be a common fault from reading about it!) and the airbag warning light is on. I am not sure if my local garage fitted the replacement indicator incorrectly and then screwed up the airbag connection at the same time. All worked fine for a week or two but the fact that the light came on and then the indicator fails to cancel on the left and won't stay on on the right makes me suspicious...
So can anyone recommend a place that is not eye-wateringly expensive? I live in the Kingston / Surbiton area.
Thanks!
Thanks!
