Servicing/upgrading in Cheltenham area.
- Thread starter ocallen
pauljmcnulty
Peter Empson
pauljmcnulty
Peter Empson
I'm nothing if not predictable [ORIGINAL: pauljmcnulty I said he'd be along soon.....[8|]
Peter Empson
I recommend you do, that's really where the air filter needs to go and there's no other good route for getting cold air into it. You'll have to use a cone filter as the S2 airbox is too tall and doesn't fit under it. It also looks great [ORIGINAL: ocallen Not sure if to fit the 924 turbo badge panel with vents that's on a shelf in my garage.
Peter Empson
My guess is if you're not tracking it then the brakes should up ok, but would strongly recommend upgrading the pads when they wear out and using only the best brake fluid.ORIGINAL: ocallen Have fitted Spax shorter front springs and adjusted the rear accordingly. Am fitting Bilsteins and rebushing. Brakes are EBC pads, new discs, stainless steel hoses. I've been told that should be sufficient but we'll see.
I also live in Cheltenham... these threads might be of use to you (see my recommendation for a specialist in the first one): http://www.porscheclubgbforum.com/tm.asp?m=195081&mpage=1&key=brian%2Cwoodward𯪟 http://www.porscheclubgbforum.com/tm.asp?m=375810&mpage=1&key=brian%2Cwoodward񛶨ORIGINAL: ocallen I've just moved into Cheltenham, can anybody recommend a good specialist in the area please ?
