Hi!
my little 88 944 lux is a daily runner which I use to and from work, she has done 116k on a full history, and although she is in need of a gearbox rebuild, and replacement sills, she is reliable and mechanically pretty sound...... HOWEVER!!!!!!!
Last night I had a bit oif a shock, after dropping off a date! I looked down at my temp gauge and she was just approaching the red line! there was no smoke, leaks, horrible oil, sweet smelling exhaust fumes, however what I did find was that the cooling fan was not switching on! So checked the fuse, I should be so lucky (Not that), so I presume the the only other bits it could be is the switch, or relay? is there anything else that I should check out at all? and how do I do it? where the heck is the switch on the rad?
Oh whislt I am on here a few other questions,
Had the oil pressure switched changed, and it is still bouncing all over the place, where is the earth point for this circuit, (as all eletrical problems so far have been a bad earth!)
Kind regards as always
Chris
Chris
