she lives !
peanut
well finally after many months of idleness ( the car not me) I managed to get the old gal started this afternoon.
After weeks of testing stuff and mucking about I finally took off all the connectors for everything and cleaned them. The earths the coil connections everything.
The three things that I believe made the most difference were.
1. cleaning the electrical terminals inside the distributor cap which were black with crud
2. cleaning the LT coil connections
3. working the injectors with a lead from the battery
when she finally fired it was on two cylinders then 3x cylinders for about 2 -3 minutes and finally the forth cylinder started firing. All the time I had to juggle the throttle carefully to avoid it stalling and cutting out.
The injectors made a helluva clattering at first but after a 10 mile run settled down.
Disks are covered in surface rust though.
I cannot tell you how marvelous it felt to drive down a lovely leafy country lane with the sun beating down and just me and the S2 and the tarmac[:D]
Good to read. What was the initial problem? It wouldn't start anymore? I took my S2 out today after a week of sorting niggles I had kept delaying for one year because of doing silly things on turbos instead. Now that it's fully operational again I think I have fallen in love with it back again [:)]
it hadn't started for nearly 5 months ! Not been good weather for working on the car outside to be honest. Its so good to be running again . I'm going to be spending some serious fettling and cleaning time in the next few weeks to make up for 5 months of neglect. You are very lucky to have both of the best 944's I have never driven a turbo. It must really be something. Enjoy.... I shall really miss you guys . I'll pop in from time to time to see how you are all doing but I shall not post here again until attitudes of certain selfish members change or there are some clear and unequivacal rules posted about non member useage of this forum so that certain members cannot throw their weight around and lord it over non members.
Well done on the repair Peanut! Please don't leave though, you've helped me out loads in the past!
ORIGINAL: peanut You are very lucky to have both of the best 944's I have never driven a turbo. It must really be something.
Worms. [:eek:] Can of. [:eek:][:eek:] Just opened. [:eek:][:eek:][:eek:] >RunsAway< Oli.
