Anyone else had this problem? If so what was your solution to removing the caliper?
Background: siezed and sheared brake bleed nipple (the car had been stood for I think eight years - I didnct think getting seven out of eight free was bad!), hence the need to remove the caliper. Unfortunately the lower brake caliper mounting bolt sheared at the head. Even with the pads removed, there is insufficient room to slide the caliper back and off the remains of the bolt. To remove the disc, the caliper needs to come off. Options I can think off are to try and drill it out (not fun on a 12mm steel, probably high tensile, in an aluminium caliper), weld something to it (again, trying to weld steel without damaging the aluminium caliper) or try and cut through it in the wiggle room between the caliper and the hub (very tight on space) I guess I could try and dremel it out. It sheared because it was tight, so not going to think of trying an eazy-out... Obviously preserving the stub of the bolt would likely ease the final removal of the remnants.
Experience and ideas welcomed!
