Last weekend I replaced the nylon parts on my shift linkage .Initially I thought the tip of the shifter rod had come loose,the tip is steel or maybe even s/steel and fits inside the end of the tube,the tube being hollow.On closer inspection there is a small pin which goes through the tube and the tip to hold it in place.The purpose of renewing the nylon was to eliminate play so when I saw this I thought this could be attributing to my problem.
Hence my question is this.Does anyone know if this play is intentional before I weld it up.
The way the tip is fixed its as if there is supposed to be movement here.
Thanks in advance.
Thanks in advance.
