Short-Shifter & Strut Brace fitted... oh my ! what an improvement !
Sundeep
got my car back last night just in time for the London meet with a Strut Brace (from Porsche UK, although slightly more than they quote so not so happy) & Short-shifter (from Gert at www.Carnewal.com great service although his online prices exclude belgium tax !) fitted..
and what an improvement ! I have been frustrated with the 'soft' front end of my 993 Targa... yes I know it's the Targa based on the Cab' ...
The strut brace has made the drive more coupe like ! much more responsive and a more dirct steering fell (which is the key !). Obviously it will never be like a proper Coupe but this is far better.. it's reduced the somewhat vague'ness that was lingered from the steering feel when cornering.. so I am now much happier..
and then there is the short-shifter.. now compared to my TT which had a Neuspeed short-shifter it's still 'long' but again a hugh improvement over (what I thought) the somewhat bus like gear change of what I used to have......!
for those who have never had a short-shifter IMHO it is a must performace mod'.. it transformed my previous TT and has done it again to my 993 ! it has had restored my faith in my car....
rather than pumping in more power, the objective was to enhance the existing driving experience...
car is 90k miles old and has recently has the differential replaced.. so changing gear has always had to be a tad delicate.. but the gear change is now a lot more precise than before and the feeling of clanging & scaping metal with metal is greatly reduced (but not totally elimated)... but there is less of a need (almost no) to partly double clutch in order to try and get a smooth gear change...
car feels more sporty ! from being able to enjoy each change more rather than worrying about imploding the gearbox with a rogue change... I still can feel the old gears/ links/ mechanism when changing but the 30% reduced throw has now given me at least 30% more driving pleasure!
[:D][:D][:D][:D]
now if I could only sucessfully blip the throttle when changing down with a bit of heal & toe [:-]
"......now if I could only sucessfully blip the throttle when changing down with a bit of teal(sic) & toe...."
We know what you meant -you may have to adapt the pedals to do this comfortably, and safely.
Mel
ORIGINAL: Melv
Mel
cheers... I'll have to have a chat with you next time...... [:D]
as for the spelling...er.. one thing at a time !
I have a targa - can you please tell me where to buy a strut and where in the car it is fitted. Is this a recognised upgrade by Porsche or an aftermarket non porsche part?
Delighted to provide you with free entertainment. I take it the question is so stupid it is not worthy of a response!
We are not all such p1ss takers as Tim & Mel (quite).
A strut brace fixes between the front and/or rear suspension turrets to reduce body roll in extreme cornering & in the case of a front brace to improve steering stability and response.
You will probably only need to invest in a brace if you going to track your car, although some club members (including a certain Mr Court) has front & rear braces on his 996 despite never having taken his car on track.
Many thanks for that Andy. I have seen a picture of a brace but it appeared to have pointed ends and I could not work out how it would be fitted. Does it bolt on to the top of the struts and run across under the front lid or is it fixed lower down?
ORIGINAL: TRW40
See these links & then all should be clear.
http://www.weltmeister.com/ProductDetails.aspx?productID=356
http://www.pelicanparts.com/techarticles/911_camber-strut/911_camber_strut.htm
"Mr Court has front & rear braces on his 996 despite never having taken his car on track. "
He also has braces on his trousers, his socks and his teeth. [:D]
Mel
PS Hallo Tim!
but....
to add.. is there an EVEN SHORTER SHORT SHIFTER I CAN GET ?????
I know the 30% reduction has helped.. but in view that the throw was bus-like long in the first place...... it is now as short as the normal gear change on my old TT...... yes, it is still TOO LONG !!!
and yes, there is no pleasing me [:D]
although I suspect there wil be nothing as short as the delightful neuspeed short-shifter that I previously had..?????
so after the GERT carnewal shoftshifter kit.. how do I go .. even shorter ??
or do I just change / renew the shift rod to make a difference ? someone mentioned this but I don't know what this would do [8|]
steady on chap.. [:D] each to their own.... [:D][:D] but questions need to be asked on forums [:-] not sure how the big red letters help ?
but seriously the comparison to the audi was used explain the benefit of a short shifter.. they are really good !
from what I have heard the RS rod should be what I am after... and those engine mounts and a must.. but sometime next year...
but what would the rod do, that my existing one isn't doing ?
but after getting my Sat Nav wired & HIFI upgraded, phone kit & roadangel installed.. I might hold off on mod's.....
for a short while anyway !
aye.. those 964's boys are everywhere !
ORIGINAL: MoC2S
If you read my post (again), the rod has less resilience in the bush .....
rather what does that really mean.. I think / I could guess the meaning but can't seem to fully understand the implication for a gear change...
Maurice -does the short shift kit change the gear lever ratio as such?
I know for instance in the Cup Car that the lever length is different to get that rifle bolt feel.
Rgds
Mel
Just a thought, does anyone know whether a shorter throw may posssibly put more stress on the synchros? (Because gears are likely to be slotted in more quickly?)
ORIGINAL: MoC2S
Lawrence, it won't damage the synchros unless you are pretty abusive (so no change there !) - I think the precision makes it more likely to slot in correctly ....
indeed....
no need to always double clutch [:mad:] just to help limit the unavoidable crunching of gears..
much more precise... even if not short enough [;)]
