During this hot spell (hot for Scotland anyway) my oil pressure gauge has been showing around 2.5 when fully warm after a spirited drive. Normally it sits at 3 and always 5 when being driven. I assume this is simply temperature related, however could it be an early warning to something more serious......having read the recent 'oil' thread most cars seem to sit no lower than 3 at idle when warm. Any thoughts.....................the oil is semi sythetic Esso 10w -50 which is at the correct level and clean.
Should I Be Concerned.........
- Thread starter ColinC
edh
ORIGINAL: Nouveau
Does Oil pressure increase when there is less oil in?
No - although it may drop off rather quickly if you run a bit too low []
