I have a 2000 996C2 cab in Dubai where I live at present. A couple of weeks ago after a 100 mile drive at speeds of between 80 - 100mph I parked up for a couple of hours. When I restarted the car there was a plume of smoke - and I mean a plume - from the exhausts. I left the engine idling and the smoke soon cleared, there were no signs of any oil leaks and temps were normal. I drove the car home without any further smoke or problems and left it for a couple of hours and re-started again and no smoke this time and it has been fine since. It doesn't use oil and oil pressure is normal at just over 1 bar at idle when hot and 4 bar at 3000rpm hot.
Can anyone explain what might have happened? Is it possible to get an oil surge into the bores - I did take a couple of corners quite quickly just before I stopped.
Any ideas and should I get it checked out?
Many thanks
Many thanks
