AndrewEllinas
I'm looking to buy a 996T or TS. Ideally seal grey or black with a black interior, and from 2004 to 2005.I went to see a car yesterday. It looked very straight and clean, but a couple of things bothered me and I would like your advice:
1. The car has had a recent 111 point check that indicated a slight cooolant leak and recommened that the radiators be replaced. The owner said that the cost of replacing the radiators made it not worth doing for a 'slight leak'. My understanding is that radiator replacement is common with turbos and does need to be carried out. Is this correct and how much would an OPC or specialist charge?
2. The 111 point check also recommended disk pad replacement, which the owner had carried out by his friend who 'prepares cars for racing'.
3. The current owner bought the car from the original owner 'a couple of months ago' and hasn't had the V5 changed into his name. There was no receipt for his purchase but he did say I could call the previous owner to check. He said he did this so that the next purchaser would still be the second owner.
All the advice I've ever read about buying a car from a private source has said that if you have any misgivings you should walk away. I have three, so you you think they are large enough for me to dismiss this car and keep on searching?
Andrew
PS: If you know anyone selling a 996T, please let me know.
