Guys
I took my car in to a non-OPC Porsche specialist to have a water leak fixed (see my previous post). This cost me about £500 and it hasn't even fixed the leak!
When I went to collect the car, they said they had performed, free of charge, the standard 111 point Porsche check. Lo and behold, they came up with a number of problems and a big quote to fix it. Other than the water leak, I don't have any issues with the car and it runs perfectly. It is a 7yr old 987 Boxster S with low mileage (30k).
Here's what they wrote in their advisory note and I'd very much appreciate some thoughts as to whether any of these are worth it (in brackets are the labour hours and the prices including parts, labour and VAT):
1. Rear Main Seal Leaking. At the same time, intermediate shaft bearing upgrade recommended. (6hrs labour, £702)
2. All 6 ignition coils recommended change. (1hr labour, £338)
3. N/S from the rod end and track rod end requires replacement. Geometry will be required. (1.5hr labour, £439)
4. Exhaust bolts require replacement in due course. Exhaust will begin to blow. (2hr labour, £216)
In respect of the RMS for 1, I have not noticed any oil leak from the car. When I told them that, they said that it is in the early stages and leaks will be hidden because it is in the tray under the car.
They also suggested I replace the front tyres due to cracking, however a trusted tyre specialist has suggested I probably have another 2k of mileage left before replacing them, so I will leave this for now.
One other thing, I took the car into an OPC about 4-5 months ago where they did a free minor check and they did not pick up any of the above points.
Please let me know your thoughts as to whether these sound like they are necessary or not.
Many thanks
Elliot
Many thanks
Elliot
