Should I replace my clutch?
- Thread starter sheldon
garyandjanet
Me i would wait.
ORIGINAL: sheldon
Had a major service on my car today and found out it needs the RMS doing.
As my car 6 years old and has done 36K would it make sense to have the clutch done at the same time? when is a clutch usually replaced?
Paul
Sods law if you don't 5 minutes later the clutch will play up and you will be stuffed with a much bigger bill and car off the road again [
JCB..
Non-member
ORIGINAL: sheldon
Paul
My clutch is still going strong at 85K (986). If your rms isn't dropping oil on the floor I'd live with it.
JCB..
ORIGINAL: JCB..
JCB..
Wise words....
John Ware
Who did your major service? If it was an OPC, they'll tell you it's failed even if there's slight seepage. I had a 48k service done on my car at Chiswick after 25k miles and they said mine had failed. I got it up on the ramps at my specialist (who now services it - that ought to tell you something) and we had a poke about to find out that seepage was almost an exagerration. It was very slightly damp. I cured it by using the car. 6k miles and six months later, we had another look and it looked like it had disappeared. I had a 12k service done just before Christmas (after another 5k miles) and it's sorted. Maybe I've been lucky.
I would suggest you leave it for the time being and monitor it reasonably closely, as I did. The average mileage for a clutch is about 50k on a C4, a bit more on a C2 so unless you drive like a hooligan, it should have plenty of life left. If it ain't broke, don't fix it. [
JCB..
Non-member
ORIGINAL: John Ware
Sheldon,
I would suggest you leave it for the time being and monitor it reasonably closely, as I did. The average mileage for a clutch is about 50k on a C4, a bit more on a C2 so unless you drive like a hooligan, it should have plenty of life left. If it ain't broke, don't fix it. []
More wise words.
Phil
In the end I got the RMS done and my OPC advised on replacing the clutch as well, (As expected there were no extra labour charges for the clutch). In hindsight I probably should have got a second (meaning specialist independent) opinion on the RMS.
For future reference Can anyone recomend a good independent in the Kent/Essex area?
Paul
