Sidelights
- Thread starter paulh3.3
ORIGINAL: paulh3.3
.... Sidelights fuse also replaced, but when I turned on the lights, the fuse blew again??? ...
This is usually corrosion around the bulb contacts shorting the circuit. Try taking out each bulb and giving the contacts (on bulb and in socket) a good clean - I scraped off the corrosion with a sharp screw driver.
BUY 4 new bulbs before U start and a tin of spray for electrical connections................ Barry
