Signature pictures?
day1zero
Please note I am an I.T numpty........how do you scale you photo dowm to 20KB so can be included on the signature pane? (Mine 1.5 to 1.8 MB!!!)....
Please help..
You need a "good" graphics package. One that can re-size pictures will intelligently adjusting the picture (rather than just chopping bits out, which the not-good ones do).
The one I use is Paint Shop Pro. You can get a free demo of it (from a number of places - just do a search).
Once installed open your file and then use Image/Resize. Check the "maintain aspect ration" box. Change the size to the max size for atvars (width). Usually it will then be under the 20KB limit too after you have saved it. If not used the OPTIONS button in the Save-As dialog and select a lower quality.
Good luck
If you are still having problems doing this and you have broadband send me an email with the file attached.
Email me via my signature.
Cheers,
Help....have managed to scale a photo down to sun 20K....many thanks for your help.. . . . . . how do you make it appear under your name tally......I have recieved the message " file uploaded " but still cant see it?????
TVM
