Silly mistake - oil
Dean Peach
I've just checked my oil in the wrong way and added a bit more, my level now shows above half way on the oil level indicator on the dashboard, and high on the dipstick, what a plonker.
an,
If the level is showing above halfway on the gauge but high (i.e. over the FULL mark) on the dipstick there is something wrong. The level you have showing on the gauge sounds about right - but it must be under the right conditions (Oil hot, thermostat open, engine idling, level ground). Same conditions if you check the dipstick.
Middle of the gauge should equate to middle of the dipstick roughly.
Dave
The gauge is not very accurate - when the oil temp is on the second mark ie the oil cooler is open, the engine running and you are on level ground the oil dipstick should be 2/3 to the full. If you go the full mark it won't harm but I always try to be just under. If you do this once and see where the oil gauge syas it is you will always have a reasonabe view of the oil level. Regards Alexander
