silly question ???
you can get blanks off e-bay; either just the metal part, the whole thing or just the plastic top. IIRC it's actually an Audi part.
ORIGINAL: guychris
thanks riverside, erm...whats a blank ? and what do i do with it ? sorry to sound dimm.
A blank is an uncut key, you take that plus one of your existing keys to a locksmith & they'll cut a copy using your original as a template.
Just done a very quick search, here's an example: http://cgi.ebay.co.uk/PORSCHE-911-964-993-CRESTED-KEY-HEAD-BLANK-OEM_W0QQitemZ220137669623QQihZ012QQcategoryZ10408QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I'm not saying 'buy this one', just showing you an example of what to look for.
hth
Or from an OPC. One of the parts that isn't as expensive as you might think as I recall.
Yes, always give your OPC a whirl. I buy most of my parts from the OPC at competitive prices.
Guychris - if you take your key fob apart you will see that the metal key can be removed from the fob itself and it is this part that you can buy a blank for. Having said that I think the whole key includingthe fob is only about £20 so if your Porsche crest is looking a bit tired then you can replace it.
Note you can only get coloured crest heads from the OPC now so if you have a pewter effect badge then hang on to it even if you prefer the coloured one.
Just for info, I have just purchased a blank (£15.58), torch key head (£14.66) and Porsche key fob (£5.96) being £42.53 all in including VAT from OPC.
Hmmm....now I write it down seems like a lot of money for a key and I still need to get the blank cut.
Very pretty though!!
I'll hang on to the pewter key head aswell, although its a bit worn now.
Well... I need to get a spare key for my '6 and if I get out the right side of £200 I'll be happy. That would be the case with any more modern car with "coded" keys to operate the immobiliser.
