I can only assume I was traveling too quickly, given the conditions and my level of skill. Had you tried to persuade me of this 5 minutes before It happened, I would have vehemently denied it. However, 40mph on a wide, open, empty A-road in Warwickshire is perhaps made a little more tricky by 4 inches of snow on the ground, and more of the stuff coming down thickly.
Thankfully, there was no-one coming the other way when I negotiated the sweeping left hand bend. Because at that point the rear end of the car decided that following the front was altogether too tedious and the taillights decided they would prefer to arrive at the destination before the headlights. The car span gracefully to the right, and once it was more than slightly underway I was no more than a passenger, although a passenger who had the sense to let go of the steering wheel, dip the clutch and NOT to brake.
Someone was watching out for us because not only were there no other cars in sight, the pirouette took us onto a grassy verge and we didn't have quite enough speed to fall into the ditch beyond it. I was deeply, deeply grateful that while the front of the car was well over that ditch, the front wheels were two inches short of it, and we had missed the last road sign by four feet or so. Getting on our way again took no more than putting the car in reverse, backing back onto the carriageway and driving off again (at not more than 20mph this time.)
I was lucky. It was a nasty moment. (Mrs zcacogp had so many kittens we had to stop to let them out a little further up the road.) And while my S2 has bitten me three or four times in the last 6 years, this was the worst by some measure. Usually I can recover things by dipping the clutch and steering into the skid, but this time there was too much momentum, too much speed and no chance of bringing things back into line.
A salutatory lesson for me, for sure. What could I have done better? What advice do you have concerning 944's getting out of line? What can you do when the back of the car swings out - I am aware that the neutral weight distribution of the 944 (engine in the front, gearbox in the back) is what makes them so stable, but will also make them fiendishly difficult to get back in line once the back is moving in the wrong direction.
And another one; does the means of recovering from a skid differ depending upon what you are driving on? I am assuming not; the handling dynamics are the same regardless of what is underneath the tyres, although slippery surfaces will mean that everything happens at lower speeds than on more grippy surfaces. (This is disregarding factors such as differing behavior of different tyres in different conditions, if not every wheel is shod in the same rubber.)
Thanks for your input.
