This has been happening ever since we've had the car. On first sweeps, the blade of the rear wiper skips across the screen, making an unholy noise and not doing much to clear water. It also happens when the screen starts to dry off after a shower and is most annoying.
If you are having a similar problem, never fear - there is a solution! [] There is a modification carried out under warranty. It's a 2 hour procedure, but seems to do the trick. We've just had ours done and now it's perfect. []
Regards,
Clive.
Regards,
Clive.
