Slicks
- Thread starter PhilRS
zub
As regards your other posting about setup, Richard Chamberlain at CTR Developments ran both cars. The Cup car won all its races so it wasn't a bad setup!
Hope that helps.
Steve Rance
Non member
hunter
But Paul would know.
As a guide I've used both Dunlops and Michelin's on track days and would say you can get an absolute maximum of 4 hours out of the rears and 6 hours out of the fronts of either make.
As Hunter suggests there are different compounds available. My experience described above is with the C and D compound with regards to the Michelin. Steve's comments will be related to the G compound which the GT3 Cups run and is softer / stickier so not sure how long they will go. I've never run them as they don't make the right size for my GT2. They were developed specifically for the GT3 Cup 30 minute sprint races.
They seem a lot more progressive than the Pirellis I used before and can even slide them around a bit -the P Zero slicks were like being on rails; timewise may have been quicker but not so much fun......[
Steve Rance
Non member
