Slight knocking noise from rear suspension
- Thread starter jetbox
They are easy enough to check if you can get the car up in the air. Just undo the lower end, and you can feel if it has any play.
This was my first item to check as I have receipts for the front drop links being changed before I owned the car but no history of the rear ones being changed.
Any other likely culprits? I would check tonight but its freezing outside in the garage.
thanks
