Hi everyone,
New(ish) member!
My 981 is making a slight rotational metallic squeal on the left hand side whenever the car is moving. I can pick up on it with the hood down, and under 25mph.
At sounds like a much less severe version of the brake squeal you get when you're on the last 50miles on a set of pads - but this sound is constant, and pads have about 4-5mm left on them. (Bent shimmy pad?)
My car has 34k miles on it, mostly motorway driving. I think a wheel bearing sound would sound more rough and grumbly, then this high pitched fine metallic rotational sound!
Has anyone had experience of a similar issue? Don't fancy taking it into the OPC for a £200 diagnostic, and walking out with a bill for ££££'s!
New(ish) member!
