Diver944
Slim, you have an Accuboost controller don't you? Can you tell me which way to turn it to lower the boost?
I have been helping a friend install a 15psi Guru kit. We have shimmed his wastegate, bypassed his cycling valve, and unscrewed tha Accuboost almost all the way out but we cannot get his peak boost below 18psi [
]. Luckily his standard wastegate still bleeds boost at high rpm so he is down to 13psi by the redline
He is certain you unscrew the Accuboost to lower it but I'm not so sure.
