SLOPPY BOX
daz944nz
Hi Guys I'm new to the world of Porsche having just purchased my 1st 944.
The car is in relatively good order apart from a few niggles.
My gear selector appears to resemble a bowl of spaghetti is there anyway I can take the slop out?
Many thanks
Darren (New Zealand)
Theres the shift lever itself, which has a joint connecting it to a shaft which goes down to the gearbox at the rear. The joint at the shift lever gets worn and can cause slop. There is also a linkage at the rear which can get worn.
The cheapest fix is to shin the gearlever / rod joint with a piece of aluminum from a drink can. Kits ate about 40 UK
Mike
