Slow fuel fill
POR_NT
I have found some difficulty when filling up my car (2000 C4 Cab), and the degree of difficulty varies slightly from garage to garage (although I usually try to use the same one, as they do RON97 at a good price).
I find that the fuel flow cuts out prematurely as it's not getting down the filler neck and in to the tank quickly enough, so I have to adjust the position of the fuel nozzle and ease off the trigger until I get the flow about right, and keep checking the pump to see how much has gone in, so I can assess which click actually indicates "tank is full"...
Apart from finding a slower filling pump (!), is there a technique or specific position that I should use?
Does anyone else have this problem?
TIA.
Very similar to when filling mine, sometimes end up with the filler handle turned 45 degrees over the bonnet! (99 C4)
But do have to constantly move it.
At first I had the same issue, I alway face the trigger towards the windscreen and no longer have problems with the fuel flow cutting off.. at any fuel stations
garyw
