SmartTOP Convertible Top Controller
pwebb
PCGB Admin
Press Release from Mods4cars for you 991 convertible owners
Las Vegas, Nevada - December 24th, 2012
The add-on SmartTOP convertible top controller designed by aftermarket
automotive specialist Mods4cars for the new Porsche Carrera Convertible
(991) is in stock available for order effective immediately. The module
allows opening and closing the top at slow speeds with just a short tap on
the console switch. Additionally the top can be operated from the factory
key fob remote, up to the full range of the RF signal and without the need
to hold a button down. A custom designed plug and play wiring adapter makes
installation as easy as possible.
The aftermarket product adds convenience and functionality to the convertible
top operation. It enhances the center console switch with one-touch auto-
operation, removing the requirement to hold the switch down. This gives
owners the opportunity to use the top more often and drive with the top down
even on shorter trips. It makes bringing the top down or back up less
cumbersome.
Additionally it is now possible to control the top from the original factory
key remote with just a quick key press sequence after which the top will
open or close fully automatically. Also here there is no need to hold down
any button during operation. "Our customers can now start a top operation
from the remote, get in the car and start the engine, while the top
continues to operate", says PR-Manager Sven Tornow. "This is not only a real
convenience but also a time saver" he concludes. With the SmartTOP module it
is even possible to control just the windows by remote, independently from
the top.
The kit offers a couple of bonus features, all of which can be individually
selected by the user via a simple setup procedure. The wind deflector
operation can be enhanced with one-touch operation as well as full-auto
operation when using the remote to open the top. A real convenience for all
Porsche Carrera owners who enjoy driving with the wind deflector up. The top
can optionally be operated with the keyless touch door handle (if
present) without the need to use the remote fob. All windows can be operated
simultaneously with the windows switches, removing the need to use the
window selector rocker and an extended mode can be activated where either
starting or stopping the engine does not interrupt the top operations. The
entire module can be deactivated temporarily as well while retaining all
user settings.
The module comes equipped with a standard USB port and cable as part of the
kit. This allows quick and easy configuration of user settings as well as
firmware updates, which are provided by Mods4cars online and free of charge.
The support software is available for Windows and Mac OS.
Installation of the kit is simple and easy. A custom designed plug-and-play
wiring adapter using original OEM connectors is included. This adapter
simply connects the module to the vehicle electronics by replacing one
single connector. No cutting wires or soldering is necessary and no
permanent changes are made. The kit can be removed at any time without
leaving any traces.
Mods4cars offers their SmartTOP solution for the following brands: Alfa,
Audi, Bentley, BMW, Ferrari, Ford, Infiniti, Mazda, Mercedes-Benz, Mini,
Nissan, Opel, Peugeot, Porsche, Renault, Volvo and Volkswagen.
The top controller enhancement kit for Porsche Carrera 991 Convertible is
available for 299 Euros + tax.
A demonstration can be seen here:
http://www.youtube.com/watch?v=kTGqb7Zz4iQ
I have used smartop for my cabs for several years and can highly recommend the unit. It is a fairly simple DIY fit.
