Smoke
- Thread starter davidp
Oil consumption is also somewhat variable with figures varying from sub 1000miles/litre to a claimed 15000miles/litre, I average circa 6500miles/litre - Porsche consider 1000km/litre or better to be acceptable.
ORIGINAL: Alex L
Only does it to me when the neighbours are watching! I can feel all the disapproving eyes on me as I pull away []
The fix I believe is to leave the engine to idle for a couple of minutes before you switch it off after you get to your destination.
It does say this in the manual:
"Do not stop engine immediately after hard or
extended driving.
Keep engine running at increased idle for
about two minutes to prevent excessive heat
build-up before turning off engine."
Wills
I always rev the engine to max on every journey I make, and did not run the engine in as some people do, I wonder if the daily use my car gets helps?
ORIGINAL: snarf
Not sure but I guess this phenomenon is not apparent on the dry-sump versions of these engines.
Rest assured, it happens [
Peely
ORIGINAL: snarf
extended driving.
Would that not be more to enable the turbo to cool down more than the n/a car ?
ORIGINAL: Peely
ORIGINAL: snarf
extended driving.
The extract is from a n/a 997 manual
Peely
The mechanics faces where a picture, running over to the car shouting....................."Noooooo !!!!" [
Also good for the brakes, if you stop with really hot brakes, the part of the disk in the caliper cools down much more slowly that the rest leading to warping.
ORIGINAL: tscaptain
and water moving at a reasonable rate
Water ? why would you need to cool the contents of the washer bottle [
ORIGINAL: tscaptain
It's due to the compressibility of air and the resultant heating of the front of the car in the washer bottle area which is achieved at the higher speeds. []
Oh, nice one [
