Steve Brookes
Moderator
The last case I saw where the front fans stayed on all the time was caused by a faulty final stage relay (the module under the scuttle panel with a big aluminum heat sink). I would start by unplugging that and putting your main fuse back in and see what symptoms you get. Hopefully, your rear blower will then stop running when the key is out (I believe you've already changed the NTC sensor which is the usual cause of the rear blower staying on) but will work when the engine is running and help pass some air from the rear cooling fan through the heat exchangers and dilute that smoke. I can't say I'm sure this will work because like many I find the 964 HVAC system very difficult to understand and trouble shoot. However, I do think that you need to solve this problem of fans running all the time rather than pull fuses to stop them.
